Timing issue
Old Oct 9, 2018 | 09:30 AM
830cmg's Avatar
Default Honda Civic Timing issues
so before we took the motor apart we didnt do a good job at marking my stuff. So we did the marking of the timing belt and all but when we took it apart, later found out there was a hole in the exhaust valve. So we replaced all exhaust valves. We put it together and it starts up sounds good but than 5 min into driving it delays and doing 30-40mph at 4,000rpm and it backfired a few. When it hits high rpm it sorta sounds normal but it bogs and studders. I know its the timing bc I know I put it on wrong well maybe... but when I pull on the belt I felt it skipping tooth’s on the clutch and fly wheel and all below. What matters when I’m doing the timing? The cam gear has “UP” which is clearly TDC. Then on the big flywheel or crank shaft wheel has 2 slits or marks but they are cut marks which mark do I line it up with that gun iron sight thing? The left mark or the right mark??? I also adjusted the valves. It’s drivable but it will die out soon, Honda Civic Ex 96 jdm D15b with a y8 head.... video below
Old Oct 9, 2018 | 12:37 PM
tony_2018's Avatar
Fish Twig
Default Re: Timing issue
I stopped at a**
Old Oct 9, 2018 | 01:32 PM
830cmg's Avatar
Originally Posted by tony_2018
I stopped at a**
now read it
haters I got
Mar 24, 2010 11:48 AM
Salsa
Feb 28, 2009 11:31 AM
SPOON_BeIgHtEeNsEe
Jul 26, 2007 01:13 PM
Y2KCivicSiR
May 9, 2005 09:56 PM
flyrod
Aug 14, 2002 06:38 PM
