Type r swap in 99 civic ex
Old Oct 9, 2018 | 07:58 AM
Cruzy's Avatar
Default Type r swap in 99 civic ex
Hey I’m swaping a 98 type engine in my ek coupe and wanted to know is there anything I have to do to the wiring add or take off anything please let me know!!!
Old Oct 9, 2018 | 11:22 AM
KiNGDEE206's Avatar
Default Re: Type r swap in 99 civic ex
If it’s coming straight from a type r u must:
use em1 harness everything plug n play. If not 99-00 ex harness. Convert dizzy to to obd2b. A rpm wire from driver shock tower
em1 t bracket
em1 post mount (block mount)
Any 96-00 rear mount
Any 96-00 tranny mount
any 96-00 stock driver mount
now you you must do ckf or whatever oil pump trick
or run obd1 ecu with obd1 ecu jumper harness and ignore the ckf sensor on oil pump
axles shift linkage plug and play
ej8_fredi
Sep 17, 2008 05:44 PM
97civicdx
Jan 3, 2005 06:32 PM
UltRaH22
Apr 2, 2004 11:05 AM
teamexcel
Feb 25, 2004 06:43 PM
bodydropranger
May 28, 2003 08:21 PM
