An OBD1 to OBD2 wire harness ecu conversion
Anyone know where I can get one? I know there is the OBD2 to OBD1 conversion all over the net. But I keep hearing people say they also have the OBD1 to OBD2 conversion harness also. If so where can I get one?
I know I guy in town that can do the wiring on a OBD2 motor to OBD1 car using an OBD2 ecu without check engine light problem. But he's just too busy..
Yea, just make your own.... it's cheaper
About the guy wiring an OBD2 ECU into a OBD1 car.... So does he bypass the secondary oxygen sensor and crankshaft speed fluctuation sensor??? Or does he just install a new oil pump with a CKFS and secondary O2.... If that's the case then i see no point in it.. Just get an OBD1 ECU.. Latez
[Modified by JDMspecEG6, 5:31 PM 11/13/2002]
About the guy wiring an OBD2 ECU into a OBD1 car.... So does he bypass the secondary oxygen sensor and crankshaft speed fluctuation sensor??? Or does he just install a new oil pump with a CKFS and secondary O2.... If that's the case then i see no point in it.. Just get an OBD1 ECU.. Latez[Modified by JDMspecEG6, 5:31 PM 11/13/2002]
email kenji at kenji211@tampabay.rr.com. he made me one. no engine check light. fixed my infamous idling problem as well.
NOman0608
Jul 26, 2007 10:28 AM
Gmedalion
Jul 10, 2002 07:56 AM
