Help with my 96 prelude
Old Sep 24, 2018 | 03:25 PM
Tracy Cagle's Avatar
Default Help with my 96 prelude
I need help, my 96 prelude has 23a1 block but has a black top vtech head. It's obd2 but harness is obd1, can't get pulse to injectors..
Old Sep 24, 2018 | 03:30 PM
Default Re: Help with my 96 prelude
Old Oct 1, 2018 | 12:40 PM
Please help. Can not get pulse at injectors, I do have power to all injectors, but put a noid tester on and no pulse???? HELP PLEASE
Old Oct 1, 2018 | 12:41 PM
HELP PLEASE
Old Oct 1, 2018 | 08:33 PM
TimiK's Avatar
10 Year Member
youre not giving enough info whats been made/changed there
Old Oct 1, 2018 | 08:40 PM
It's an h23a dohc, vtech, I've put 2 resistor boxes on it tried 2 different ecu, I have power to the injectors, but no pulse. I've put a noid light on the plugs, no pulse. It's an obd1, have new inline fuel pump, plenty of pressure to fuel rail. It has a distributor with external coil...
Old Oct 1, 2018 | 08:42 PM
It had a small fire by the mastercyclinder, but harness was replaced hasn ran since. If you spray 2+2 in the intake it will fire
Old Oct 2, 2018 | 12:59 AM
hondamyheart's Avatar
92-96 prelude OBD1 not OBD2. Make sure you have the correct injectors for your engine/ecu first. Check the fuses, pull the ecu codes, check the thermostat ground.
rsxdc52002
Mar 3, 2010 09:49 AM
illicon2003
Apr 1, 2004 07:49 PM
dohcnotec
Jan 25, 2004 08:28 PM
ludespeeder
Jun 21, 2002 11:34 PM
da6_b17a
Oct 20, 2001 05:29 PM
