Overheating problems
Old Sep 22, 2018 | 12:39 PM
Ryebread1974's Avatar
Default Overheating problems
So far I have replaced the radiator, water pump, cooling fan switch and thermostat.
In the car, the dashboard says the car is not even hot. But when I open up the hood radiator fluids steaming everywhere. I know I need to do a pressure test to see where and if it's holding pressure. My part of me feels like the radiator is clogged.
Any help would be appreciated.
Old Sep 22, 2018 | 05:10 PM
Turbo1983's Avatar
Default Re: Overheating problems
Have you try to start car cold with radator cap off just to make sure water pump is working an have you seen fan come on??
Old Sep 23, 2018 | 04:49 AM
mk378's Avatar
Where does the steam come from? Is it not just a simple leak? In normal operation the coolant will be hot enough to make steam anywhere it leaks out.
Old Sep 24, 2018 | 04:24 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Did you change the radiator cap, I had one bad once and did that
carrollrucker
Aug 28, 2013 11:09 PM
MFButler
Mar 11, 2010 11:30 AM
zbower7
Sep 14, 2004 02:44 PM
bigslimdog
Aug 10, 2004 03:37 PM
dbman96
Aug 8, 2001 02:24 PM
