Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
RR uses for Lexan?
Old Sep 16, 2018 | 01:42 PM
iwannarace's Avatar
Default RR uses for Lexan?
I have a chance to pick up a bunch of large lexan plates for less than half-off retail prices. I'm just not sure what I would use it for. Thoughts? I can make my own blackbird fabworx style wing for the teg, but I'm not sure what else to do.
Old Sep 16, 2018 | 03:51 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: RR uses for Lexan?
Depending on the sanctioning body you run in, you can replace your teggy's side windows reducing weight.
Where are you in the bay? I might wanna reduce my EG's weight some more
Old Sep 17, 2018 | 12:30 PM
iwannarace's Avatar
Livermore. I went ahead and picked up about 32sqft for $100. Figured I'd find a use for it sooner or later.
Old Sep 17, 2018 | 12:46 PM
dirty19's Avatar
Ridin Dirty in Cali
I used to live in Livermore up till a few months ago.
32 SQ FT?
That's a lot.
How thick is it?
Old Sep 17, 2018 | 06:39 PM
iwannarace's Avatar
3mm
Old Sep 17, 2018 | 06:57 PM
killerpenguin21's Avatar
sheet lexan is a pain in the *** to use for anything thats not a flat window. there is a company in the uk that makes formed direct replacement windows, for like 500 bucks shipped (i run them on my integra)
Old Sep 19, 2018 | 02:32 PM
dirty19's Avatar
Ridin Dirty in Cali
Originally Posted by iwannarace
3mm
Should be sufficient thickness not to crack if its not tightened down too tight.
Rivnuts would work I believe..
Old Sep 21, 2018 | 03:47 PM
DaIll1's Avatar
If you want to do you back glass, just place a slightly larger piece on said, well supported window and slowly warm and cool it. Don't try to heat it with heat gun or torch.
importfanatic17
Jan 19, 2007 01:43 PM
will7
Jan 10, 2006 07:54 PM
i2ydon
Dec 22, 2004 03:23 PM
Full Race A6
31
Jun 28, 2004 07:39 PM
N4Speed07
Aug 14, 2001 11:01 AM
