Cluster lights
I have a 96 Honda Civic ex. My speedometer, fuel/temp, and tachometer lights went out while driving. The turn signal, check engine, and those lights work. Could it be a fuse or a bigger issue?
Yes most likely the dimmer control but check a couple of other things first. First check that the tail lights and corner lights on the outside of the car still work, since they are powered from the same circuit at the light switch. Then there is a 3 amp fuse only for the dash lights. It is prone to blow if you have an improperly installed aftermarket radio.
The dimmer control pops into the dash, carefully pry it out with a flat screwdriver. Unplug the dimmer plug and jump the solid red wire to the solid black wire and turn the light switch on. The dash lights should now come on fully bright. If that works, replace the dimmer.
Integra4lyfe069
43
Oct 11, 2017 09:57 AM
Soulman41
Sep 25, 2014 10:00 AM
bambam530
Oct 27, 2013 07:12 PM
slob20ef
Mar 30, 2009 05:43 PM
NatedoggAZ
Feb 10, 2006 11:00 AM
