Swap/Axle Questions
let me get this straight first... a 92-95 JDM B16 INTO YOUR 92-95 US CIVIC?
if so, you are fine using the axles from the JDM B16 car.
or any Integra 94+ will work also.
and Del Sol DOHC VTEC axles will work also.
Whoops, forgot to add that info.. its a '98 Hatchback DX.. sorry
ABS TOOTH GEAR?
explain...
Me? I am using 94 teg axles w/ ABS "gears" on them on my non-abs 92 civic with a GSR swap.
I think the confusion from axles comes from the recent posts about JDM ITR axles having a larger axlenut and larger hub on 5 lug setups... this guy needs none of that jazz.
explain...
i see....what i was trying to say is that he should just go ahead and use non-abs axles for the simple fact that he doesnt have abs and he wont have that gear spinning around down there...my post had nothing to do with a larger diameter JDM 5lug axle???
forever slow EG6
Aug 11, 2004 09:20 AM
