Previous/current F20c F22c, H, and B engine builders
Old Sep 12, 2018 | 06:12 AM
Primetimeswole's Avatar
Default Previous/current F20c F22c, H, and B engine builders
Weighing my options:
1.) Build my S2000 with 600 whp range = estimated $10k+
2.) Purchase a clean hatchback, boost H22 or B18C1 or B18B, 600 whp+ range = $10k or less?
With the FRM in F20c F22c and H22A requiring a sleeve rebuild, I am leaning towards the B series motor for major boost goals.
Hesitant to even crack open F motor since home garage rebuild 'is not recommended'. So the H22A is a nice candidate.
Note: I will be installing and tuning myself so trial/error will mean a possible engine replacement. In terms of my willingness to spend money, I am not looking spend too much due to #Adulting.
Build goal is to run 1/2 mile races, decent decent handling for street, and get those Lambo kills. This turbo build will be a weekend/ non-daily driver.
For previous/current owners who are running boost, are my budget prices accurate? What types of setbacks have you experienced?
Any input would be greatly appreciated.
Old Sep 12, 2018 | 07:12 AM
Cupajoe's Avatar
Default Re: Previous/current F20c F22c, H, and B engine builders
you should pay a tuner that is experienced and knows the platform and power goals you are going for otherwise you are wasting time/money unless you plan to open a tuning business of your own and want to practice on your car for a while till you nail it.
Old Sep 12, 2018 | 07:51 AM
Chance EG's Avatar
600WHP can be done on a bone stock F20/F22C with a good tune. Since you're tuning yourself though, you probably won't want to take that risk.
Sleeves with a B or H will be mandatory for 600+, or with a B series engine at the very least CSS.
Your budget is too small when considering the chassis, engine, fuel, EMS, and turbo components needed.
Old Sep 12, 2018 | 07:53 AM
Autoworks's Avatar
Originally Posted by Cupajoe
you should pay a tuner that is experienced and knows the platform and power goals you are going for otherwise you are wasting time/money.
Agreed. It would probably actually cost less in the long run to just have a seasoned tuner tune it.
IMO, a 600hp S2000 and a 600hp FWD Civic are 2 really different animals when it's all said and done.
I've owned a 600+whp D series and own a 600+ whp S2k now. They are just different types of "fast" for me. Both have (had) sleeved blocks... (as far as the S2k goes, the block wasn't the hardest hit $ wise...it was the rear end conversion)
Old Sep 12, 2018 | 09:21 AM
Txdragon's Avatar
Limited budget, extravagant goals, finicky platforms, beginner build.. What could go wrong?
Old Sep 12, 2018 | 04:00 PM
Thanks all for your detailed replies.
What is the realistic budget for a 600 hp car? I am leaning towards a civic hatchback because of cheaper replacement parts specifically the motor.
Old Sep 12, 2018 | 04:17 PM
Txdragon's Avatar
Depends heavily on which engine. You can easily surpass 15k on any of your chosen platforms, providing you do the work yourself.
Old Sep 13, 2018 | 12:42 AM
Balor_Gr's Avatar
With how cheap K24s are at US for 1/2 mile /roll racing it becomes very obvious K24 with a K20A2/Z3 is very capable. EFR9174 was htting full boost at 4500 on a k24 (...)
FWD guys most of the times forget the cost of the rear differential (in europe they use 300zx if i remeber correct and someone did an M5) and axles (it happens with new BMW guys too)
Old Sep 17, 2018 | 01:43 AM
What about boosting a d16 for 400+ hp? What is the budget range?
Is it even worth the time building a sohc?
Old Sep 17, 2018 | 04:09 AM
Autoworks's Avatar
Building a 400hp D series is a great option...but what is it that YOU really want out of the build?
Old Sep 17, 2018 | 04:43 AM
Balor_Gr's Avatar
-D16
-CSS block
-YCP/custom lengh rods
-mini ram
It must be like the best bang for your buck like ever.
Old Sep 17, 2018 | 06:35 AM
Great question. My end goal is to build a high horsepower turbo car (leaning towards civic hatchback or coupe) for weekend (occasional) driving/drag racing/half-mile racing. As mentioned before, this project will be self tuned/built so I will be leaving a generous margin for errors. So a replacement engine is possible.
Any idea on the expected budget range for a 400+ whp turbo d16 setup? Everything prior to chassis modifications and professional tuning to clean up my tuning.
Originally Posted by Balor_Gr
-D16
-CSS block
-mini ram
Thanks for your information. This is a great starting point for me and anybody else looking to build a home-built project car.
preluder90
Apr 26, 2014 09:07 PM
spowns
Jun 5, 2005 02:22 PM
1fastvtec
Apr 20, 2005 09:26 PM
nocsyn
Jun 4, 2004 10:22 AM
n_t_civic98
11
Jul 16, 2002 06:48 PM
