2000 civic won’t start after fuse box relocation and wiring converted
Old Sep 11, 2018 | 08:32 AM
hondamyheart's Avatar
Default 2000 civic won’t start after fuse box relocation and wiring converted
Hi
I had relocated my fuse box inside the car and made custom obd1 harness for my 2000 civic. Now if I turn the key on fuel pump will prime but I have steady cel. The car will not crank.engine is h22, Ecu is obd1 p28. I tried my spare ecu no success . I checked a25,B1 for power and a23,a24,a26 and B2 for ground.also I checked the thermostat grounds and cleaned it. I jumped the starter engine will crank but not start.
Old Sep 11, 2018 | 09:22 AM
tony_2018's Avatar
Fish Twig
Default Re: 2000 civic won’t start after fuse box relocation and wiring converted
ecu power and ground? hope you didn't cross wires? Did you pull the cel?
Old Sep 11, 2018 | 01:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You screwed something up hondamyheart... and nobody here can help without seeing what you have done. You will have to go back through ALL of your modified wiring and trace your steps. Good luck.
Old Sep 11, 2018 | 09:34 PM
I didn’t cross the wires. I double checked. I pulled the cel but steady cel.
Old Sep 11, 2018 | 09:37 PM
i know there is something missing. Because I tried my ecu on my brother’s car it works perfectly. I checked the wiring twice with the diagram still no luck . I am thinking maybe some wires to the dash are missing.
Old Sep 12, 2018 | 05:00 AM
mk378's Avatar
Check that all the power pins on the ECU have power. Check that the +5 volt sensor power bus comes up. Pay particular attention to main relay wiring. When the CEL comes on and doesn't go out with key on engine not turning, something is rather fundamentally wrong.
Old Sep 12, 2018 | 11:40 AM
tony_2018's Avatar
Fish Twig
I'd just say look it over again
Old Sep 13, 2018 | 05:56 AM
I just found out that Connector D pin 1 wire is cut. D1 voltage backup. What is the function of it? I am going to run a new wire and see if car starts without issues
Old Sep 28, 2018 | 07:49 AM
I was away for 10 days. The car still won’t start. Got the rid of cel. It will not crank, if I apply 12v by jumper wire the car will start but stalls. Any ideas what to check next? Ignition coil?
Old Sep 28, 2018 | 08:15 AM
tony_2018's Avatar
Fish Twig
Stalls cuz the ecu not telling injectors to fire and the fuel pump not getting power
look over your work and check your grounds.
Old Sep 28, 2018 | 11:48 AM
NVturbo's Avatar
O.G. triple O.G.
Honestly, what's a realistic reason why people relocate the engine bay fuse box? Just to show off that there are less stuff to see? Half of the time, it's done incorrectly...hence this thread.
Old Sep 28, 2018 | 12:12 PM
tony_2018's Avatar
Fish Twig
boom, grill cheese
Old Sep 28, 2018 | 12:31 PM
thanks buddy. Fuel pump getting power, i will check the injectors.
Old Sep 28, 2018 | 12:35 PM
i am doing this build for myself not to show for people, I don’t go for meets alot.
Old Sep 29, 2018 | 11:34 PM
so I had the starting issue done. There car converted to manual, so there was 2 wires need to be shorted for the gear position to make the ecu thinks it is park position. Now I have to deal with the stalling issue, going to check the injectors first
Old Sep 30, 2018 | 11:06 AM
tony_2018's Avatar
Fish Twig
Its so hilarious cuz you didn't bother to state that in the OP.
Old Sep 30, 2018 | 10:07 PM
This is the first time i am making a custom wiring so i didnt knew that these wires needed because i fully removed all dash wiring.
Josh Huff
Honda Civic (2001 - 2005)
Feb 9, 2016 05:54 AM
yoleoj
Apr 8, 2014 03:45 AM
miguey310
Sep 13, 2011 07:55 PM
lawlsss
Nov 1, 2009 05:46 PM
eg_gsr11
Jun 20, 2006 03:44 PM
