Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
TPMS Sensor Broke
Old Sep 10, 2018 | 09:40 AM
drsab2000's Avatar
Default TPMS Sensor Broke
2008 Civic Coupe EX: So during a tire swap, one of the TPMS Sensor broke off the stem. I searched on the forum for info on the procedure for replacing/relearning and can't seem to find anything. I was going to purchase a new sensor from Rockauto (Standard Motor Products) or is it better to get one from Honda (Honda Parts Unlimited). Will I need a special tool for programming? Can someone direct me to a discussion on this subject. Thanks in advance.
Old Sep 11, 2018 | 12:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: TPMS Sensor Broke
If you buy one from Honda, all you have to do is bolt it into the wheel, air up the tire and put it back on the corner it was removed from (do not rotate yet until it has communicated with the TPMS system) and it will set itself. Buying a cheaper replacement (especially a "universal" type) from another source may require additional equipment and/or professional assistance to get it to communicate initially with the car. You choose.
Old Sep 11, 2018 | 12:57 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
A new TPMS sensor must be programmed. Easier to just go a dealer, tire store, or service shop to have them do it.
it needs a TPMS programmer.
Old Sep 12, 2018 | 12:18 PM
drsab2000's Avatar
JRCivic1
Thanks for the reply. I talked to a tech at Honda Parts Unlimited and he confirmed that the sensor will program itself as you indicated. Thanks for your help.
malottauto
Nov 28, 2017 10:38 AM
gizmo923
Sep 12, 2017 08:59 AM
Dc2phil
Sep 17, 2012 01:34 PM
samvtecaccordsport
Apr 27, 2004 04:48 AM
