Engine mount bolts needed: D15Z1 engine into 1987 Civic AF chassis
Hello all!
This is my first, but not likely last, post here on the Forums. I'm trying to track down info on the proper engine mount bolts for a D15Z1 engine swapped into an '87 Civic chassis. Will these have to be special ordered, or could I just grab the proper bolts from the hardware store (provided I have the right bolt measurements)?
Thanks!
Thanks!
That is not a bolt in application... what mount kit are you using to install the D15Z1 engine/trans ???
