Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
hydraulics
Old Sep 1, 2018 | 10:13 AM
alibat's Avatar
Default hydraulics
hello i have a 2005 honda civic manual. I have installed a used trasmission but lost hydraulics line. Car starts ok but i got no pressure in clutch pedal. i have changed master cylinder and slave cylinder bleed the lines till no air is coming out of the bleeder i still have no pressure in pedal and slave cylinder not moving when pedal pressed.
please help!
thanks
Old Sep 1, 2018 | 11:53 AM
thisguyaves's Avatar
Default Re: hydraulics
Try bleeding again. Have you filled your reservoir recently? Remove the slave cylinder, press the pedal, and see if the piston moves at all.
Old Sep 3, 2018 | 08:00 PM
alibat's Avatar
hello i have tried bleeding again i have success in bleeding fluid streams out of bleeder when pedal held in, but the piston does not move at all. i have found a small leak at under the 16mm flarenet on the master cylinder i bought the cylinder new but had to buy the flare nut from the dealership it came with a gasket i installed and a cotter pin i have tried to hammer in the flare nut by placing a wrench horizontally on it and hammer it in the cylinder not to damage the nut. not sure if this is the correct way as it is not listed in the service manual there a small gap left and i think that is where fluid escapes while pedal being pressed. could that possible be the cause the piston on slave doesn't move when pressing pedal even though its bleeding with pressure?
thanks
Old Sep 4, 2018 | 07:51 AM
Absolutely. Not enough pressure to effect movement on the slave against your clutch fork and pressure plate.
jonina
15
Jun 1, 2012 08:19 PM
Born2Build
May 22, 2011 06:02 PM
superfuji57
Sep 28, 2004 01:02 AM
infamousALLMTR
Apr 15, 2003 09:48 AM
