No power at Starter. Will not start. Everything else is good
Old Aug 31, 2018 | 07:11 AM
Darrell Woods's Avatar
Default No power at Starter. Will not start. Everything else is good
Starter well not in gauge,/ all else works good. I use a remote Push button Switch plugged directly into starter solenoid, starts right up! No power at Starter ... I replaced the eletrielec key switch, Main Relay.. is there a Starter Relay somewhere? All help is Greatly appreciated!!
Old Aug 31, 2018 | 08:32 AM
egsleepercivic's Avatar
Default Re: No power at Starter. Will not start. Everything else is good
The power wire for the starter should run directly off the battery, there is a trigger wire on that connects with a spade connector, also check the safety switch on the clutch sometimes the rubber stopper comes off and the safety switch doesn't get pressed.
This is info for a 94-97 teg, you didn't tell us what year, I assume integra, is it auto or manual and what year, also wtf does this mean " I use a remote Push button Switch plugged directly into starter solenoid, starts right up! " if it starts right up, what is the problem ?
Old Aug 31, 2018 | 10:19 AM
Default Re: 95 Integra LS 2 door hatch 5 speed.. Will not start. Everything else is good
I Remove the solenoid wire on the starter. Use my cam adjustment starter Bump switch to start car. No power at solenoid during Start-up.
Old Aug 31, 2018 | 12:07 PM
check the safety switch and stopper
here is what i am talking about if you are not sure
https://honda-tech.com/forums/honda-...ement-3088503/
shows a civic but it is the same\similar for a teg
Old Sep 2, 2018 | 03:13 PM
Found Issue! Starter-cut relay..
Denso 056700-8570 20amp relay.
No one has this Exact relay. Only Dealerships. My guy down at O'Reilly Auto parts, Cross it to a generic 30amp relay Masterpro # 2-JR65.. put it in, Works like a charm!
Last edited by Darrell Woods; Sep 7, 2018 at 04:03 AM. Reason: Edit misspelled word
Old Sep 6, 2018 | 04:59 PM
tamboo's Avatar
10 Year Member
the denso relay is available used on ebay and i'm sure elsewhere:
https://www.ebay.com/sch/?_nkw=Denso%20056700-8570
seems to be a booming trade since it's discontinued.
i'd grab one just cuz i love me some denso qualitay. 8)
Old Sep 6, 2018 | 10:52 PM
Jimmy's Avatar
Global Moderator
No one has this Exact relay. Only Dealerships. My guy down at O'Reilly Auto parts, Cross it to a generic 30amp relay Masterpro # 2-JR65.. pulled it in, Works like a charm!
Relay located in fuse panel?
Old Sep 7, 2018 | 04:13 AM
Above the fuse panel, far left next to several Other Relays mounted with a 10mm bolt
Old Sep 7, 2018 | 06:09 AM
How I identified the proper relay (several in that area) was the wiring colorations black with a white stripe 10 gauge ...
PhilUp24
Aug 16, 2013 06:15 PM
apm
10
Mar 30, 2013 08:57 PM
bge9198
Jan 18, 2012 07:43 PM
wesk18
Dec 6, 2010 11:06 PM
