Em1 and Del Sol Oil Pan
Old Aug 29, 2018 | 03:07 PM
Bryedawg's Avatar
Default Em1 and Del Sol Oil Pan
I have a dumb question; I smacked my oil pan on my 2000 Civic Si (Dohc 1.6L B16a2) and now it's leaking. My buddy has an extra New oil pan off a 1.6L Sohc 2000 del sol or 90 something, idk...
Can i possibly install this Sohc oil pan on my 2000 Civic si Dohc b16a2 to save some money? 😅
Old Aug 29, 2018 | 05:03 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Em1 and Del Sol Oil Pan
no.
Old Aug 29, 2018 | 10:23 PM
tony_2018's Avatar
Fish Twig
op should ask his older brother
Old Aug 30, 2018 | 02:39 AM
NVturbo's Avatar
O.G. triple O.G.
if you can't afford a $40+ oil pan, YOU SHOULDN'T BE DRIVING in the first place.
Old Aug 30, 2018 | 08:26 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
OP, you will have to use a "B" series oil pan. The Civic Si uses the same pan as the '94-01 Integra LS/RS/GS, '94-97 Del Sol VTEC (B16A3/2), and the '97-01 CR-V. You can even use an Integra GSR or Type R oil pan, but they hang down slightly lower than what you already have, so the risk of damage with that pan is even greater than what you already smashed.
Once repaired, you may want to raise the car back up a bit to reduce the chances of smacking your oil pan on something else and placing you back in this position.
ruff93sol
Apr 25, 2014 09:52 AM
The_Snowflake
Nov 9, 2011 11:13 AM
Del Sol Man
13
Dec 20, 2004 08:58 AM
crxbust
Apr 4, 2004 06:53 PM
