Fuel pump not priming(99 ex B20 swapped)
Old Aug 28, 2018 | 05:45 PM
Randomnoob's Avatar
Default Fuel pump not priming(99 ex B20 swapped)
I just swapped a b20 into my coupe and it ran fine for two days then the fuel pump stopped priming(couldnt hear it click on anymore) I changed the main relay a month prior to doing the swap, Grounds in Engine bay are all fine, any thoughts? Thanks- Daniel
P.s I dont know how old the fuel pump has been in the car ,I bought it and swapped the b20 within a couple months of owning.
Old Aug 28, 2018 | 07:38 PM
egsleepercivic's Avatar
Default Re: Fuel pump not priming(99 ex B20 swapped)
do you get power at the pump when you turn the key to the "on" position?
Old Aug 28, 2018 | 08:42 PM
Randomnoob's Avatar
When I turn the key to “
On “ position I would usually hear it click(prime) and I dont hear it anymore. I dont have any meters to test for power or volts
Old Aug 29, 2018 | 04:23 AM
mk378's Avatar
When you turn the key on but don't crank, the Check Engine light should come on then go out. The main relay should click on and then click back off at the same time as the light going on and off. Does it do that?
Old Aug 29, 2018 | 12:26 PM
If you don't have a volt meter \ multi meter, why even bother posting on here, sorry to be harsh, but you can get one for free from harbor freight with a coupon.
and before you say where do I get the coupon, well here you go
http://clipperclipper.com/coupons/Cl...5~01~15~01.pdf
just go buy a box cutter for 29 cents and get the multi meter free
que6977
Sep 17, 2012 04:10 AM
radicaled434
10
Apr 27, 2012 04:10 PM
gsr_sleeper916
Mar 27, 2011 06:59 AM
89vwfox
Feb 4, 2009 08:10 AM
99'b16at
Mar 15, 2006 08:47 PM
