Difference between 93 EG spindles vs LS?
Old Aug 28, 2018 | 11:52 AM
K-G's Avatar
K-G
Default Difference between 93 EG spindles vs LS?
So today I went to replace my rotors and brakes today but come to find out when I bought rotors for a 93 civic ex the rotors wouldn’t fit over the hub. The ones I bought were smaller then the ones that were on the car.
So I returned the ones I bought and ended up getting 93 LS rotors and they fit and were the exact rotors. When I bought this car 4 years ago i guess they had replaced the spindles with LS ones.
My question is why would someone replace them with LS ones ? Is there any benefits ?
Old Aug 28, 2018 | 12:48 PM
Feriohhh's Avatar
5 Year Member
Default Re: Difference between 93 EG spindles vs LS?
EX civic should be the same 10.2" front brakes as on the Integra. The first ones you got were likely incorrect and for a CX/DX/VX etc.
Old Aug 28, 2018 | 03:21 PM
K-G's Avatar
K-G
that’s what I thought to ... but we even looked in the computer to verify the right part and they were the same size I got. We compared the LS and they were slightly bigger rotor & perfect match. I’m pretty confused lol
Old Aug 28, 2018 | 05:07 PM
94EG8's Avatar
Seagull Management
Parts store lookup is wrong, unless you're in Canada and looking up rotors for an EX sedan without ABS.
People generally run Integra spindles to run bigger front brakes. Integra and Civic EX spindles are nearly inentical, Same mounting points for everything and they used the same wheel bearings.Integra is slightly heavier though.
Old Aug 29, 2018 | 02:45 AM
K-G's Avatar
K-G
cool thanks for the little schooling. I suppose the product that was in the box was packaged wrong then. Regardless at least they’re the same size and **** so it didn’t matter which one I use.
Old Aug 29, 2018 | 03:05 AM
K-G's Avatar
K-G
I was just curious because I believe when I was putting my ITR calipers on my type s I heard the “right way” was to get the type r front end ***** and convert it all but then your offset changes. So I just wasn’t really sure what was going on with the eg lol! thanks again ! Like I said, it probably got packaged wrong and sold to me.
i hate autozone
thanks again brother
Old Aug 29, 2018 | 03:13 AM
K-G's Avatar
K-G
Actually I did some digging around and I have found out that according to autozone the 93 LS rotors are bigger than the eg. LS hub center size is 152.2 and the EG is 136.4.
My issue was the rotor wouldn’t fit onto the hub because the rotor center was to small. The LS ones are bigger and slipped perfectly onto my hub. I believe I really do have LS spindles
Old Aug 29, 2018 | 02:04 PM
Feriohhh's Avatar
5 Year Member
For the NON-EX civic, that's right. You said your car is an EX. 1993 EX 1.6 SOHC VTEC is exactly the same rotor as all Integras (not the Type R)
Look at an actual Honda/Acura parts lookup (available online).
  • 1993 Civic EX front rotor: 45251-SCC-901
  • 1993 Integra RS/LS/GS/GS-R front rotor: 45251-SCC-901
For fun's sake, I looked at AutoZone:
1993 Civic EX and 1993 Acura Integra are both the same rotor part numbers:
  • 3295
  • 3295DG
  • 31029DG
  • 3295GT
Brembo exactly the same for both the 1993 Civic EX and 1993 Acura Integra:
  • 45251SK7A00
Old Aug 30, 2018 | 01:14 PM
94EG8's Avatar
Seagull Management
^Mostly correct. '92 - '95 Si Hatch (except '94 ABS) had small CX front brakes though.
Old Aug 30, 2018 | 02:19 PM
Feriohhh's Avatar
5 Year Member
Opps, you're right. Fixed. Thanks
y2kferari
Feb 3, 2007 07:44 AM
CheEsEsTeAk168
Sep 17, 2005 09:48 AM
CheEsEsTeAk168
Aug 31, 2005 02:14 PM
420aNT
Mar 2, 2005 07:22 AM
White92Hatch
Jul 1, 2003 04:29 PM
