Non OEM piston rings in an h22a4?
Old Aug 25, 2018 | 02:54 AM
Blake St.romain's Avatar
Default Non OEM piston rings in an h22a4?
Am I able to use non oem piston rings in an h22a4? Honda oem rings are insane. Its going to cost over $200 just for rings. I understand these engines have an frm coating. Would I be ok with hastings piston rings? They are way more affordable. Thanks
Old Aug 25, 2018 | 12:16 PM
Aradin's Avatar
Premium Member
Default Re: Non OEM piston rings in an h22a4?
Yes you can use the Hastings rings. The FRM sleeves have no effect on anything other than the ability to safely run an aftermarket forged piston. The nice thing about them is you don't have to hone them when you re-ring the engine unless there are deep scratches that run the length of the bore.
Old Aug 25, 2018 | 12:27 PM
Awesome! That's exactly what I needed to hear. Thanks
Old Aug 26, 2018 | 08:34 PM
TimiK's Avatar
10 Year Member
Nippon (makes Type S pistons)
turbo boost
Oct 27, 2014 11:09 PM
hondachris1994
23
Feb 9, 2009 07:55 PM
Drew17th
Oct 28, 2006 06:02 AM
quik1
Jun 19, 2004 06:33 PM
Cyber ITR
May 18, 2002 02:28 AM
