Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
No start don't know why
Old Aug 24, 2018 | 07:16 PM
b3nma0's Avatar
Default No start don't know why
I have a 2001 civic and I can't figure out why it won't start. It cranks like normal but, it won't start running. I recently changed the fuel pump and sock. The relays seem like they are working and I don't see any blown fuses. I also checked my plugs and coils and they work fine. Battery is new and so is my alternator. I also changed out my cam position sensor and my timing belt seems pretty good. I also check if fuel was coming off the line and some comes out. The car pretty much stopped working out of nowhere, I drove it to work and when I was about to go home it would not start. Also when I was checking around I did notice I have no coolant left could this cause my no start too?
Old Aug 25, 2018 | 11:35 AM
thisguyaves's Avatar
Default Re: No start don't know why
Check compression, that's about the last thing.
Old Aug 26, 2018 | 01:04 PM
b3nma0's Avatar
I put some starting fluid into the throttle body and it started like normal. I did notice that my fuel isn't making it to my engine. My guess is that i have to change the rail and injector?
JDM Freakk
Jun 21, 2011 05:36 PM
Leks
Apr 10, 2009 06:00 AM
feava510
Feb 15, 2009 10:59 AM
civic efb16
Aug 8, 2005 09:00 PM
whitecrx
Jun 6, 2005 07:47 PM
