Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 ex coupe 1.7 v tech motor 2001 ex coupe exhaust manifold with cat built in
Old Aug 24, 2018 | 12:22 AM
jimdamico's Avatar
Default 2002 ex coupe 1.7 v tech motor 2001 ex coupe exhaust manifold with cat built in
I have a 2002 honda civic ex coupe bought it with no cat just a piece of flex pipe from header to exhaust pipe the stock converter was located under the car due to the high price of a ca epa approved one a friend of mine had the exact same car but it was a 2001 i was told 2001 to 2005 were all the same so i took off his stock exhaust manifold with an up stream and down stream o2 sensors made a new header pipe to connect to exhaust and lengthened o2 downstream sensor wires started it up check eng light went off about 1 min later came back on bank 1 heated o2 sensor 2 when i scanned it po141 code what do i have to do to remove this code for smog wide ban narrow band ecu any help is appreciated PPPPPPLLLLLLEEEEEEEAAAAAAASSSSSSSSSSSSSEEEEEEEEEEE EEE
Old Aug 24, 2018 | 04:01 AM
mk378's Avatar
Default Re: 2002 ex coupe 1.7 v tech motor 2001 ex coupe exhaust manifold with cat built in
You're in the wrong forum. 2001-2005 model is considerably different from the 1996-2000 covered here.
As generic advice, throwing the O2 sensor heater code immediately on startup usually means one of the following
- sensor bad -- its heater is open (can be checked with ohmmeter)
- faulty wiring
- blown fuse
Old Aug 24, 2018 | 03:42 PM
thisguyaves's Avatar
Pre-face (01-03) and facelift (04-05) civics (EM, ES chassis) are similar but have subtle differences. 01-03 should be the same within their TRIM LEVEL AND CHASSIS. Different D17s used different exhaust setups. I'd go junkyard one.
ludecrasy87
Jan 15, 2015 08:13 PM
BAM! 93 hatch
21
Oct 27, 2011 09:46 PM
jerryscherry
10
Jun 9, 2011 08:57 AM
Paulnsx
Mar 26, 2005 04:56 PM
Wazup
Nov 13, 2002 02:25 PM
