Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Need Advice on Replacement Wheels...
Old Aug 23, 2018 | 07:30 PM
sparkyk20eg's Avatar
Default Need Advice on Replacement Wheels...
Looking for replacement Wheels for my EG race car. Currently has 949 Racing Wheels... 15x8 +36 on Rear and 15x10 +25 on Front. 949 did not make 15x10s on their latest production run and the 15x9s wont hold the 275/35/15 and the 15x11 are too wide. I was told Jongbloed Racing made similar sizes but when I contacted Phil's Tire Shop (I guess the exclusive dealer) they are not available from them. Wanted to get four fronts and four rears, but am at a dead end on finding anyone that makes these sizes. I guess I could consider customs but that would be an arm and a leg. Any advice or guidance greatly appreciated.... especially if you know where to locate up to four 949 Racing 15x10 +25 wheels. I included a pic of the car. It is a blast to drive on the track. Has a K20 swap and was set up with no expense spared. Bought it from a friend as is sits.
Old Aug 24, 2018 | 07:50 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: Need Advice on Replacement Wheels...
you wont find the 949s and all your other options are in the $500/each range... Works, Volks, etc... IF they are event in stock anywhere also.
Old Aug 24, 2018 | 09:15 AM
ross2004's Avatar
You can always go steel, circle track style wheels. Cheap, and not that heavy.
Old Aug 24, 2018 | 10:13 AM
Kaan's Avatar
Loved
Community Favorite
shenanigans .... my wifes jeep is on 15x8 steel wheels... lord have mercy
Old Aug 24, 2018 | 11:06 AM
ross2004's Avatar
I don't think 21# is too bad for a 15x10 steel wheel, but ok.
Bassett 15" Diameter D-Hole Lightweight Racing Wheels Asphalt or Dirt
Old Aug 24, 2018 | 03:10 PM
iwannarace's Avatar
Maybe check with the guys at goodwin, or flyin miata. I'd say pose this question on trackhq.com if you haven't already.
Old Aug 25, 2018 | 08:30 AM
killerpenguin21's Avatar
the konig dial in and the advanti storm both come in 15x9, a lot of 15x10's have dried up it seems.
hard to tell from the pic, but what tires are you using? and whats the rest of the setup suspension/power wise. maybe its an opportunity to try a slightly different setup
Old Aug 25, 2018 | 08:52 AM
Running Hoosiers R7's 275/35/15 on front and 225/45/15 on back. Has coil overs with super stiff springs. Has a k20 swap and dynoed around 237hp and drives likes its on rails. The previous owner spent a ton of time dialing it in so was hoping to leverage off his work. The fronts have 10mm spacers (probably for clearance of the Wilwood bog brake kit) , the rear has 3mm spacers.
I'm relatively new to the Honda world so any advice is much appreciated.
Old Aug 27, 2018 | 05:59 AM
Kaan's Avatar
Loved
Community Favorite
K20 speed... extra weight on the wheels will murder your tires and brakes every weekend.
AntMan401
Jun 18, 2007 03:53 PM
Rahjahdat
Jul 17, 2006 11:08 AM
R-Toyz.com
Aug 25, 2005 12:01 PM
integrated civic
Aug 24, 2005 03:06 PM
