Noise after clutch replacement
Old Aug 20, 2018 | 06:21 AM
cwadamson's Avatar
Default Noise after clutch replacement
1998 honda civic DX 5 speed manual. I replaced the clutch and pressure plate and throwout bearing this weekend. i drove it home 30 miles with no noise. drove it this morning and it grinds sounds like brakes grinding. it only makes the noise when the it is in gear foot off clutch pedal and coasting.
Old Aug 20, 2018 | 04:52 PM
Turbo1983's Avatar
Default Re: Noise after clutch replacement
Have you adjusted your peddle? Did you change the pilot bearing (the bearing in flywheel) when you changed pressure plate etc?
Old Aug 20, 2018 | 05:20 PM
cwadamson's Avatar
I did not replace the pilot bearing. Did not know you can adjust the pedal. Also confirmed on the way home when in neutral and coasting foot not on the clutch pedal there is not noise.
Old Aug 20, 2018 | 05:26 PM
Turbo1983's Avatar
Almost sounds like the pressure plate is allowing the clutch to still drag/grab while pedal is being pressed. Adjusting the pedal deceased or increase pressure to clutch slave cyclinder.
Turbo1983's Avatar
Why didn't you get the flywheel resurfaced
Old Aug 20, 2018 | 06:26 PM
mk378's Avatar
Is there fluid in the transmission?
darmstro
12
Jul 2, 2009 03:52 PM
SuperMaing
Mar 17, 2009 08:53 PM
NeverLift
Sep 18, 2008 10:40 AM
b19coupe
Sep 1, 2003 09:12 AM
