Hi guys sorry if this has been asked a hundred times.
I experienced no idle issues nor any CEL upon firing it up for 15 mins but the engine temperature shot all the way up when taking it around the block. Pulled up the hood to see evaporating white steam. I realized I should've burped the coolant following the swap but after pouring some into the radiator I can hear and see coolant leaking under the engine.
Did I use the wrong intake manifold gasket, connect the wrong hose somewhere or forgot to block something? I know with the engine turned off but with the heater blowing the temperature dropped to normal after a minute.
D16Y8 Intake Manifold
Shot of my head after scrapping the old gasket off
The IM gasket I'm using from eBay
Coolant hose going to the valve next to the IAC
Second coolant hose going down to water bypass
Photo by Pata to illustrate the two hoses I talked about earlier and hose going from the PCV valve
PCV valve hose up to the top nipple and fuel line connected to the fuel pressure regulator at the end there
Hose connected to the EVAP there behind the intake manifold
Yeah I got underneath and tried but couldn't find the source. Considering buying a UV light detection kit.
I'm wondering if the intake gasket doesn't match now that I examine the cutout and look back at where it fits on the head. All the hoses look fine and because the leak is so consistent as I pour into the radiator if it was huge hose tear I feel I would see it.
So I found the leak! The giant coolant line located under the fuel rail and first fuel injector. Couldn't find any tears on it. But looking back wondering if I stretched out the end too much when trying to remove it for the swap.
I think I'll try cutting off that end and re-connect then pour some more fluids to see if it keeps leaking.
So the fatter bypass hose under the first injector is where the leak was and my mechanic told me the valve/metal rod is probably damaged on the inside and it's pretty corroded on the outside.
To be fair I did get it from PnP and at least the intake manifold is cheap so I'll stop by to get another one sometime this week to swap.
