AC - High side is low, low side is high.
I recently went to recharge my ac, and the guages showed the low side being high and the high side being low, it took most of the 12 ounce can that I put in and then wouldn’t take any more. Any thoughts on what could be causing the problem or possibly how to fix it? Thanks in advance!
What car? Was the compressor clutch running? A high low side and low high usually means the system is either off (equalized) or the compressor is weak.
We're going to need a bunch more information to help you out. Let us know how you charged it, and if it was from a deep vacuum. What's the history of the system, ambient temperatures, and any other miscellaneous symptoms it may have?
arielb1
Jul 15, 2017 04:43 PM
RFEwing
Aug 15, 2016 10:20 AM
Muckman
Jun 1, 2011 10:59 AM
