Should you use thread sealer on the fuel line from tank?
Old Aug 16, 2018 | 04:49 AM
K5hunter's Avatar
Default Should you use thread sealer on the fuel line from tank?
Put on the new filter and I have fuel spraying out of the line coming from the tank. Not cross threaded. But when I can't tighten the with the line wrench anymore, it is still not sealed. Do I just need to REALLY torque the hell out of it?
Old Aug 16, 2018 | 04:52 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: Should you use thread sealer on the fuel line from tank?
should be a washer or seal ring from my memory , make sure you didn’t miss putting it back on
Old Aug 16, 2018 | 05:21 AM
K5hunter's Avatar
The line is a flange metal line with a hollow line nut. Inside the filter I see a "crowned" or cone shaped seat. The line should just tighten down on the flange of the line, right? I do notice some of the yellow seal compound Honda uses on the threads and line. That is why I thought I should maybe use some lock-tight. Can't see any seal or washer in the old filter.
Old Aug 16, 2018 | 07:49 AM
2x0's Avatar
2x0
10 Year Member
I use the white pipe compound thread sealer on all of my fuel fittings and have no issues. Not sure if it is a correct application but it works.
Old Aug 16, 2018 | 11:28 AM
Chance EG's Avatar
Anyone else used teflon tape for this? Not sure if that's correct but I've done it before when re-assembling.
Old Aug 16, 2018 | 12:50 PM
2x0's Avatar
2x0
10 Year Member
That's what I used to use all the time. Then I ran out and the liquid thread sealer was cheaper than the tape so I went with that
Old Aug 16, 2018 | 02:17 PM
mk378's Avatar
Putting sealant on the threads of a flared connection will not stop leaks. The seal is made between the tapered flared end of the tube and the seat in the fitting. It is metal on metal so the nut needs to be rather tight. Putting oil on the threads will increase the sealing force for a given torque. But mostly the seal surfaces need to be the proper shape and smooth. Try putting the old filter back on, if it doesn't leak you have a bad new filter.
carlos8
Jun 8, 2015 07:15 PM
HondaKid936
Jan 29, 2008 12:59 PM
JLefevers
Jan 1, 2008 09:20 PM
tcfsurfer
Mar 30, 2006 06:26 PM
