96 Accord lx overheating
Old Aug 13, 2018 | 06:14 AM
Greg B's Avatar
Default 96 Accord lx overheating
So I have a 1996 Accord lx with the 2.2 L4 sohc. Recently it has begun to overheat. After some quick diagnosis I replaced the thermostat. Now the radiator fan won't turn on(ac fan works just fine).I know there is a temp switch for the fan. I found two sensors but I don't know which one is which. They both look the exact same except one has a black end and one has a brown one. The black one is on the top radiator hose next to the block. The brown one is on the thermostat housing. Help me. Thank you in advance.
Old Aug 15, 2018 | 11:54 AM
hondamark35's Avatar
Default Re: 96 Accord lx overheating
I can never remember which switch is which, I just try each (one at a time) with a paper clip. if the fan doesn't turn on with either then I put power direct to the fan connector. by then I know what needs replacing and have forgotten already which connector I checked...
Old Aug 18, 2018 | 07:06 AM
Greg B's Avatar
UPDATE: got a chance to work on the car. The cooling fan sensor is on the thermostat housing, however replacing this did not solve my issue. The cooling fan still won't turn on. any ideas?
Old Aug 18, 2018 | 07:18 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The radiator fan motor may be dead. Apply direct power and ground to the fan motor and see if it runs.
Kimura97
May 2, 2019 01:01 PM
Jmullins665
Aug 27, 2017 09:40 AM
Pure Sol
Apr 20, 2011 04:01 PM
chechea
Aug 8, 2007 08:56 PM
B16Power
Mar 28, 2005 11:32 PM
