99 d16y8 Head gasket - cylinder head/engine block
Old Aug 12, 2018 | 07:49 AM
Just1nK4ng's Avatar
Default 99 d16y8 Head gasket - cylinder head/engine block
3rd and 4th block
1st and 2nd cylinder
Full shot block... rust :X
Full shot cylinder
1st and 2nd kcm
Check out the middle of cylinder
3rd and 4th cylinder
Check it out I finally removed my head...
I need to know the fill-gap size for max amount of gap for both block and cylinderhead.
another big issue...
rust and residue
there is rust in my block and the cylinderhead.
is it bad to the point i shouldn't work on it?
Old Aug 12, 2018 | 07:52 AM
Just1nK4ng's Avatar
Default Re: 99 d16y8 Head gasket - cylinder head/engine block
Also If you u look at picture of "middle of cylinder head" you can see the valves on 3rd and bottom ones and 2nd top ones are slightly opened.
Is something wrong?
Old Aug 12, 2018 | 08:57 AM
tony_2018's Avatar
Fish Twig
love the look of your coolant passage ways. What coolant did you use?
Old Aug 12, 2018 | 09:16 AM
Just1nK4ng's Avatar
so the story goes....
i dont know what happened....
previous owner must have used water and/or Oil change shop. I only use oem.
Not sure... pervious owner I am guessing. U shoulda checked out the radiator. *_*
Old Aug 12, 2018 | 09:17 AM
Just1nK4ng's Avatar
Keep u updated
Old Aug 12, 2018 | 09:52 AM
tony_2018's Avatar
Fish Twig
I would suggest downloading the FSM, it has the information you need on how much you can take off before the head can no longer be used.
You can take the head to a machine shop to clean up and reassemble
Old Aug 12, 2018 | 10:41 AM
mk378's Avatar
Examining the old head gasket is usually the best clue to where it blew out. The "fire ring" area is the most critical.
Is that missing metal at the intake side of #3 or just some black gunk?
And yes the cooling system is really crudded up.
Old Aug 12, 2018 | 07:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
When the camshaft is left "in cylinder head" when the head is removed, there will be at least two pair of valves open at any given position.
Old Aug 13, 2018 | 03:21 AM
NVturbo's Avatar
O.G. triple O.G.
I'm betting someone left the block exposed to the weather...like outside in the rain with the hood open.
Old Aug 13, 2018 | 05:42 AM
tony_2018's Avatar
Fish Twig
See all that build up on the wall? God damn.
Old Aug 16, 2018 | 02:44 PM
Just1nK4ng's Avatar
Can I soak purple stuff and rinse with water to remove some of the rust inside the cylinder head?
Old Aug 17, 2018 | 02:43 AM
NVturbo's Avatar
O.G. triple O.G.
take it or ship it to a reputable shop to have them clean the block
soundquest
Sep 22, 2017 03:25 AM
03_EX
Honda Civic (2001 - 2005)
Aug 4, 2017 07:28 AM
kc7
Apr 19, 2009 07:13 AM
b16 matt
Oct 6, 2004 10:01 AM
