B18c1
guys I have a problem I have a built engine I started first time today je pistons eagle rods head work. I purchased golden eagle head gasket advanced seal. I started it first time today and I look at radiator oil pumping out of it can someone please help thanks... I’m wondering if I put it on wrong because I put it on the with the word up showing but also seen a video of one person put one on with gem up so please can someone help
Last edited by Em1Dustin; Aug 12, 2018 at 10:27 AM. Reason: Not a great enough explanation
I personally would immediately pull the plugs and do a compression test, it’s almost sounds like the head gasket did not seal at all properly or you have a crack inside the block somewhere. Do a compression test and post the results
Thank I will do and post results someone said head gasket could be on wrong
Instead of what do I think, at this point it's probably better of what should you do. If you have oil filling up in your radiator obviously something should probably come apart. I mean if it were me I would probably pull the head, that would probably be a good start. Or take it to a professional and have them see what the problem is.
THATS WHAT I AM DOING TODAY BECAUSE IM LOST
RaceCleaner24
Jan 6, 2016 03:19 AM
