Clunk noise and intermiten pulls when turning
Old Aug 9, 2018 | 08:53 PM
Jan-DA's Avatar
Default Clunk noise and intermiten pulls when turning
Last week my cable trans broke and I was no able to get the sameone. Ended up buying a S4C no lsd hydro and did the swap. I drives good strait but when turnin, a clunking noise and intermittently pulls happens ( like whe welded or issues with lsd but none of these apply)
Im running the DA9 axles, and synchromesh fluid.
I lifted the car and ran it in gear and axle bearing seems to be traveling fine inside the cup, hower the I was able to see a lot of play between the cup and the transmission and the clunking noise was going.
Axles use to work perfectly fine with the cable trans
Maybe trying another fluid?
I'm having a bad feeling about the spyder gears...
anyone experienced something like this?
Old Aug 14, 2018 | 06:31 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Clunk noise and intermiten pulls when turning
try axles that fit the hydro trans....
Jan-DA
Transmission & Drivetrain
Aug 10, 2018 08:05 AM
New Fella
Aug 6, 2013 08:03 PM
honda93
Feb 21, 2005 02:03 PM
