Clutch pressure plate question
Old Aug 8, 2018 | 07:29 PM
foolsforever's Avatar
Default Clutch pressure plate question
Hey guys,
Whenever I installed the pressure plate I forgot to do it in a two-step sequence and just went straight to 20 ft pounds on those 10mm bolts. Will this do any harm? Also, would it make any difference if I took them out and then re torqued them properly, or is it too late? Thanks.
Old Aug 9, 2018 | 06:47 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Clutch pressure plate question
It might cause it to be out of balance, not really speaking from experience though. If it were me, I would be paranoid and redo it in the proper sequence.
Old Aug 9, 2018 | 08:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I don't remember the factory spec being a two step process. I think it is straight to 20 ft/lbs anyway... however, there is a proper sequence. It is a double triangle pattern: Start at any bolt, torque it and then skip one clockwise and torque the 2nd one... skip one and torque the 3rd bolt of the "triangle"... then skip two bolts (move straight across the flywheel) and torque the 4th bolt, skip one clockwise and torque the 5th bolt, then skip one and torque the 6th bolt. Then double check all six in a clockwise pattern to make sure that you didn't miss any.
Old Aug 9, 2018 | 09:36 PM
Vryantec's Avatar
Originally Posted by foolsforever
Hey guys,
Shouldn't be much harm as long as you did them in the right sequence. Did you at least use loctite on them?
Old Aug 10, 2018 | 02:23 AM
Yeah, I used the star pattern from the manual and put on some thread lock.
Axatax
Transmission & Drivetrain
Jun 28, 2012 09:53 PM
Jdmdelsolb16a
Engine Management and Tuning
May 11, 2011 06:11 PM
jweeks
Apr 24, 2007 05:26 PM
pip9
Jun 3, 2004 05:50 PM
jonsteR
Aug 10, 2001 08:55 AM
