Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
diff and speedometer gears not meshed
Old Aug 6, 2018 | 04:59 PM
Thundergod67's Avatar
Default diff and speedometer gears not meshed
I have a '01 Civic with the 5spd trans, that needed a new clutch. While the trans was out of the car, I thought I would put new bearings in the transmission. I have replaced the input shaft bearing, the intermediate shaft bearing, and both differential bearings. When I test fit the case back together with only the diffential inside, I get a LOT of clicking noises. They seem to come from the worm drive gear of the speedometer sensor moving up and down as it turns, instead of just staying in one position. The diff spins really nicely when installed in one side of the case only...as long as the speedo sensor is not installed as well!
I really need the car back together tonight, and was hoping someone could help!!!
Thanks!
Peter
Vagitarian
Feb 24, 2014 06:31 PM
be18see1
Transmission & Drivetrain
Feb 11, 2009 09:07 AM
wiZCo
12
May 14, 2007 09:16 PM
Y2ksi
Oct 29, 2005 05:45 PM
user 98292739
Feb 21, 2005 02:27 PM
