Troubleshooting: 2002 accord V6 hesitation between 1000rpms & 2000rpms
Old Aug 4, 2018 | 02:37 PM
sippyaccord's Avatar
Default Troubleshooting: 2002 accord V6 hesitation between 1000rpms & 2000rpms
my kids 02 accord hesitates Around 1000 to 2000 and acts if it’s starying for fuel
new plugs, new fuel filter and pump, new radiator, thermostat, temp sensor not sure what else to do please any help will be appreciated
Old Aug 5, 2018 | 08:11 AM
DumpdEJ6's Avatar
I like the tuna here
Default re: Troubleshooting: 2002 accord V6 hesitation between 1000rpms & 2000rpms
Is the Check Engine Light on? Might want to go to Advance Auto or Autozone and have them check for codes first.
Old Aug 5, 2018 | 08:57 AM
I had a check engine light with a bunch of misfire codes and an EGR code so I changed all the plugs and cleaned the EGR then cleared all the codes and drove it for 2 days no new codes but still have the same problem especially when it’s cold
Old Aug 6, 2018 | 01:23 PM
Default Re: Troubleshooting: 2002 accord V6 hesitation between 1000rpms & 2000rpms
Ok the car set overnite drive it for 2 minutes and I get a CEL AND TCS light and the following codes p0301,p0302,p0303,p0304,p0305,p0306 and p0300 all with the flashing cat, Eva, o2s, EGR lights on the Innova 3150 coder
WTH is going on
Old Aug 11, 2018 | 05:17 AM
so still the same thing happens
I took it to Honda to get the timing belt changed they did there scan and found nothing wrong and it drove good for them, because it was warmed up I guess.
when I got home I scanned the car and found a abs code 31-02 right inlet valve malfunction and retard throttle can this be my culprit
​​​​​​​any help
Old Aug 17, 2018 | 11:19 AM
Update
so after all of the before and now a new timing belt kit and new o2 sensors and the intake air sensor, I thought it was good to go. drove good for one day then I drove 15 miles to the store came out started ok then I pulled out in the parking lot engine warm and the rpm went to under 500 and the speed dropped as if I had lost power
im absolutely lost please help if you can
Old Aug 18, 2018 | 09:54 AM
DumpdEJ6's Avatar
This is very hard to diagnose without being there in person, and problems that come and go like what you are describing, doubly so. Do your dash lights flicker when it starts doing its issue? It almost sounds like wiring is grounding out somewhere.
You say this happened when the engine was warmed up, does it do it with the engine cold? We need as much information as possible, otherwise there's no way to even hazard a guess at a diagnosis.
Does it do it when you are giving it a certain amount of throttle? Can you MAKE it do it, or does it just do it on its own? If you can replicate the issue, and do it on demand, that will give you the direction to start looking in, and is the first step in diagnosing an intermittent problem.
Old Aug 18, 2018 | 11:09 AM
somick's Avatar
Can your scanner monitor the O2 voltage?
It could be your dying sensor.
Good luck,
Sam
akacivic
Jul 22, 2021 02:44 PM
prafulhonda
Sep 22, 2017 03:10 PM
caddy500
Oct 6, 2015 05:01 PM
huntozmer
Sep 15, 2014 09:24 AM
