B/D series Power steering
Old Aug 2, 2018 | 05:53 AM
RVMIRXZem1's Avatar
Default B/D series Power steering
So Im throwing a 00’ B20B into my 99 ex coupe ( 5 spd ) . What parts would I need to change out and what can I re use for power steering
Old Aug 2, 2018 | 06:27 AM
hybridnorth's Avatar
Default Re: B/D series Power steering
You will need a pump off of a 99-00 SI Civic or 00-01 Integra (Doesn't matter if LS.GS,GS-R) then your existing hoses will work. I just b-swapped my 99 ex and used a pump off of a 00 LS. You may want to grab the block mounts just in case, I'm not sure if the B20 is different.
Old Aug 2, 2018 | 08:28 AM
RVMIRXZem1's Avatar
Alright thank you
Old Aug 2, 2018 | 09:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Are you using a complete B20B engine ??? If so, you only need to get a '97-01 CRV P/S bracket and the three bolts that fasten it to the engine. Your stock Civic P/S pump will bolt to that bracket. If you intend to swap to a VTEC head, then you will need to do as hybridnorth suggested... and don't forget to get '94-01 Integra LS/RS/GS upper and lower P/S brackets.
Old Aug 3, 2018 | 07:04 AM
RVMIRXZem1's Avatar
thanks really appreciate it
Civic HX 121
Jul 28, 2016 06:47 PM
khailon
May 7, 2011 10:49 AM
mhewitt
Mar 16, 2011 05:09 AM
2005avtj
Jan 21, 2009 08:17 PM
ohsnapzafingcu
Dec 8, 2008 07:22 AM
