ej1 power steering problem
I have a 94 ex coupe with a b20 swap... i have read around about the power steering problem that u need the right upper bracket and lower bracket in order for it to work correctly... i am using my d series steering pump on the b series mounts. it bolts up but it seems like my pump is alittle out of line with the crank pulley. What would happend if i leave it like that?
Re: ej1 power steering problem
Nothings going to happen, your just not going to have power steering. You can take the pump off and cut and loop the powersteerring lines if you decide that you dont want it.
Mainsubject
14
05-04-2013 03:34 PM
