Front LCA Replacement Options
Old Aug 1, 2018 | 12:12 PM
2x0's Avatar
2x0
10 Year Member
Default Front LCA Replacement Options
I am looking at all options available for front LCA replacements on a CRX. My bushings are pretty shot, and rather than try to replace them individually, swapping out the entire arm seems much more efficient.
I would prefer poly bushings, but every option I can find either has hard rubber or spherical bearings. I know the sphericals are not good for a street car, so I guess I will go with rubber unless anyone knows of a decent poly option.
- Skunk2 and Hardrace both make some that I'm sure are decent, for about $200 for the set. This is what I am leaning towards.
- Then there's Mevotech etc. other OEM replacement brands that can be much cheaper.
Am I wasting my money by going with Skunk2 or Hardrace? Any reason not to buy these?
Old Aug 1, 2018 | 12:36 PM
Tyson's Avatar
Default Re: Front LCA Replacement Options
do you think theyre any better than OE aftermarket?
https://www.partsgeek.com/gbproducts...ad=47433967692
$32 for perspective....
Old Aug 1, 2018 | 12:55 PM
2x0's Avatar
2x0
10 Year Member
I have no idea, that's kinda why I'm asking lol.
From a performance perspective, I assume they have stiffer bushings which I would prefer. But as far as longevity, fitment, etc. goes if anyone has experience with them I would like to find out whether they are worth the cost.
Old Aug 1, 2018 | 03:15 PM
tommycrx's Avatar
You’re right - they’re stiffer than stock. I just got the Hardrace myself, so I don’t know the longevity of them, but I only drive my car in summer, so that’s not a big concern.
But I’d assume that they’d last as long as any stock replacement at least.
Old Aug 1, 2018 | 05:34 PM
rileybuildsaciv's Avatar
I got an entire bushing set from hard race and pressed out the old bushings. I had to turn some pieces of metal to press on just the outer race of the bushing. The bushings in the lower control arms were rusted in there, so I had to cut them out with a skill saw and hammer them out. If you don't have tools to do this job I'd just recommend getting the entire control arm.
I'm satisfied with the bushings. They are stiffer, but aren't too harsh for daily driving in my opinion. I have new shocks and my car is at the stock ride height, so that probably helps soften things up. If all your bushings are shot it may be a good idea to get them all done.
Old Aug 1, 2018 | 06:04 PM
sumdewd's Avatar
Are the LCA bushings the only thing you're going after?? And why would you prefer poly?
I installed a full PIC/Sonem hard bushing kit on my 90 Si HB in 2010. It was about $180 I believe, but it's been a while. It included like 36 bushings.. I forget. I purchased a $140 hydraulic press from Harbor Freight since the local machine shop wanted to rape me for $10-$30 per pressed bushing. It was honestly not too difficult after you get past the rusted suspension bolts. I did snap some suspension bolts off and had to replace all 4 shocks, but it was needed regardless.
No squeaks, since it was hard rubber and not BS poly. The ride is definitely more stiff, and I still don't have any clunks or broken bushings to this day.
Old Aug 1, 2018 | 08:11 PM
2x0's Avatar
2x0
10 Year Member
Original plan was to do a master poly bushing kit. I am trying to get everything tightened up, and will be riding on 550# springs front and rear so I want everything to match. Always used poly bushings in the past and have been happy with them.
But after reading what a pain it is to replace the front lca bushing, decided I would just get new arms. Plus I already have S2 rear lower arms, front uppers, and poly RTA bushings. So the front lca is my main concern at this point.
I will be alright with harder rubber. Thinking I will order the Hardrace lca’s at this point.
Old Aug 5, 2018 | 08:50 PM
Marcos Barrios's Avatar
dude check out my build thread
marcos new work car 90 sedan
i just did the front lca bushings
and showed how to do the job yourself
with both arms done i spent about 60 bucks useing oem honda bushings that will last
at least 15 years no matter what kind of driving you do
Old Aug 6, 2018 | 02:21 AM
2x0's Avatar
2x0
10 Year Member
Okay thanks, I will be sure to check that out!
Old Aug 6, 2018 | 07:49 AM
NAS_OCSICNARF's Avatar
Hasport is the only brand that I would buy suspension components for an EF.
Hasport
Old Aug 7, 2018 | 08:15 AM
Hasport's Avatar
Hasport
thanks for the support unfortunately we dont make suspension components
Old Aug 7, 2018 | 08:32 AM
oops. Oh man...I've been out the game too much and haven't updated myself.
Old Aug 7, 2018 | 05:51 PM
acmoc's Avatar
Just get oe replacements from autozone or somein.
ocJDM4dr
Suspension & Brakes
Sep 23, 2014 12:36 AM
turboef90
Suspension & Brakes
Jun 2, 2013 05:37 AM
Mike239
Suspension & Brakes
Mar 11, 2011 10:26 AM
dc-2_mike
Jun 2, 2009 05:34 PM
guy_from_nerk
39
Aug 1, 2008 12:13 PM
