95 integra bogs out after launch
So I do the launch control take off go to switch a gear and punch it again and it just bogs out and then shuts down the more gas I give it b4 I shut down the more it bogs down no matter if I push in the clutch or not I’m running a b20b with ls trans looking to see what might cause this
Something to do with your "Launch control", either a switch or setting?
Coil
Igniter
spark plug wires
spark plugs
mechanical timing
ignition timing
fuel injectors
fuel pump
FPR?
Coil
Igniter
spark plug wires
spark plugs
mechanical timing
ignition timing
fuel injectors
fuel pump
FPR?
SimplyTron
Feb 19, 2007 12:08 PM
