ls/vtec not running right
i have a problem with my ls/vtec its runs but i get a check engine light and it says ignition output signal and fuel injectors. i have put new spark plugs in it new spark plug wires and i took the plugs out after lettin it sit for an hour and they were still soaked in fuel. wut is goin on?
i just bought the car and it was running fine all i did was tighten the timing belt
anyone that knows wut might be goin on please help me asap
Re: ls/vtec not running right
yes and no, ignition control module is inside the distributor.
could be a bad module, loose wire, etc etc. get a multimeter out and troubleshoot it.
or you could just buy a whole new distributor.
what's the code for the fuel injectors? you should trouble shoot that too, to eliminate any suspected problems so that you fix the right thing the first time.
the code for the fuel injectors is 16 and i dont have a multimeter and wut u mean lose wire and would the dizzy send it too much fuel
well i will gladly take it to a pro if i had the money to get raped by them so thats y i came to here so i can get advice isnt that wut this site is for
