D15B7 3 stage vtec swap O2 sensor CEL
Old Jul 25, 2018 | 10:46 AM
Kylegregg's Avatar
Default D15B7 3 stage vtec swap O2 sensor CEL
Ive been searching all day with no conclusive results.
CAR/MOTOR: D15B7 3 stage vtec swapped into a 96 CX hatch. ECU is JDM P2J-003 and is utilizing the factory non-vtec engine harness.
ISSUE: CEL with code 1 flashing on the dash. Car runs and drives fine but i want this CEL gone.
The factory harness utilizes a 4 wire primary O2 sensor. From research, i believe the JDM P2J utilizes a 1 wire o2 sensor. Car has an aftermarket header back w/ welded in high-flow cat (w/ provisions for secondary o2 sensor, but i believe this JDM ECU does not need a secondary o2.
Thanks! I hope i provided enough info.
How do i go about modifying the 4 wire to be compatible with the 1 wire ECU & 4 wire harness?
Old Jul 25, 2018 | 11:03 AM
tony_2018's Avatar
Fish Twig
Default Re: D15B7 3 stage vtec swap O2 sensor CEL
Just plug it in.
Old Jul 25, 2018 | 11:08 AM
Kylegregg's Avatar
Originally Posted by tony_2018
Just plug it in.
it is. still have code 1. thought there might be a wiring issue. the o2 bung is on a single header runner, not sure if that makes a difference.
Old Jul 25, 2018 | 11:11 AM
tony_2018's Avatar
Fish Twig
Cc has both o2 harness up front. You sure you have the right plug?
Old Jul 25, 2018 | 11:42 AM
Kylegregg's Avatar
swapped them with no change. still has CEL. the dash shows one long flash continuously....im assuming this is code 1 being repeated.
Old Jul 25, 2018 | 01:00 PM
tony_2018's Avatar
Fish Twig
SO FUNNY, I DON'T HAVE THAT PROBLEM BUT ONLY YOU. WOULDN'T KNOW WHAT ELSE TO TELL YOU. TAKE IT BACK TO THE PERSON WHO WIRED IN THE OTHER SENSORS THAT ARE NEEDED?
Old Jul 25, 2018 | 01:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I thought the 3 stage needed the 5 wire wideband O2 sensor just like the VX (vtec-e) motors do to run lean burn mode.
Old Jul 25, 2018 | 01:07 PM
tony_2018's Avatar
Fish Twig
NO SIR, THE D15Z7 3 STAGE USES A SINGLE WIRE, THE SIGNAL WIRE. THE OP SEEMS TO HAVE, QUESTIONABLE THAT IS, A D15B7 3 STAGE THAT ALSO REQUIRES A SINGLE WIRE, AND IT SHOULD BE THE SIGNAL WIRE.
Old Jul 25, 2018 | 02:09 PM
Kylegregg's Avatar
i think i might have figured out the problem. my 'code 1' might in fact be 'code 10'...which is IAT sensor. i took out my IAT sensor and the tip is melted in half. ill report back tomorrow once sensor is replaced.
Old Jul 25, 2018 | 03:12 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good to know, thanks Tony!
Old Jul 26, 2018 | 01:23 PM
Relic1's Avatar
long flash = 10's digit
short flash = 1's digit
example: single long flash and two short flashes means CEL 12
thread that goes into more detail here
Melted IAT is a common issue when you have the EVAP purge solenoid and IAT plugs swapped (same plug, same area, bad design by honda) make sure you have it the right way or you will destroy the next IAT.
Old Jul 26, 2018 | 01:34 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Isn't there also a chance to pop one of the transistors or chips on the ECU?
I thought I saw a replacement ECU component on xenocron that mentioned swapping those plugs.
Old Jul 26, 2018 | 06:43 PM
tony_2018's Avatar
Fish Twig
This is why you don't just quickly start plugging in everything, you take your time and identify the plug.
t-del28
14
Feb 28, 2013 06:43 PM
EX-T
Apr 24, 2006 02:55 PM
Cutlass355
Apr 30, 2005 03:31 PM
quik89
Jul 24, 2004 03:40 PM
hatchman92
Oct 14, 2002 01:06 PM
