D16Y7 and D16Y8 bottom end...same??
Old Nov 13, 2002 | 12:19 AM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
Default D16Y7 and D16Y8 bottom end...same??
Are they the same? Or is one better/stronger than the other?
Old Nov 13, 2002 | 04:09 AM
thinkbrianthink bu's Avatar
Default Re: D16Y7 and D16Y8 bottom end...same?? (VitaminB20)
yes
no
[Modified by thinkbrianthink, 7:09 AM 11/13/2002]
Old Nov 13, 2002 | 09:00 AM
sleeprhatch's Avatar
both paper weights
Old Nov 16, 2002 | 09:50 PM
DX187VTEC's Avatar
Default Re: D16Y7 and D16Y8 bottom end...same?? (sleeprhatch)
paper weights haha....like that
Old Nov 18, 2002 | 11:05 AM
4potnick's Avatar
Default Re: D16Y7 and D16Y8 bottom end...same?? (DX187VTEC)
The compression is the same with either head on either motor then right. just curious.
Old Nov 19, 2002 | 03:29 AM
Default Re: D16Y7 and D16Y8 bottom end...same?? (4potnick)
actually compression is higher on the y8 due to pistons (i believe)
Old Nov 19, 2002 | 03:57 AM
dlm's Avatar
dlm
Default Re: D16Y7 and D16Y8 bottom end...same?? (thinkbrianthink)
^^higher compression due to vtec valve train, and thinner headgasket
d16y7 and d16y8 both have the same block, and all the internals are the same, it's just the heads that are different...but the y8 head flows better than the y7...
Old Nov 19, 2002 | 08:13 AM
4potnick's Avatar
Default Re: D16Y7 and D16Y8 bottom end...same?? (dlm)
so a y8 head on either a y7 or y8 block will yield the same compression.
Old Nov 19, 2002 | 11:48 AM
X2BOARD's Avatar
Some wrong info going around here.
The Y7 head yeilds 0.2 less compression than the Y8 head due to a large combustion chamber (lower CR)
Y7 head's combustion chamber= 34.6cc CR= 9.4:1
Y8 head's combustion chamber= 32.8cc CR= 9.6:1
Same pistons is memory serves...
The Y8 also comes with a super thin stock H/G.
X2
Old Nov 19, 2002 | 12:25 PM
Kataku2K3's Avatar
Default Re: D16Y7 and D16Y8 bottom end...same?? (X2BOARD)
X2
Damn that's sort of like P72 and PR3 heads... 0.2:1 difference... hehe
Old Nov 20, 2002 | 06:41 PM
4potnick's Avatar
does this mean that i can use stock cam gear with y7 bottmom and y8 head. just curious.
Old Nov 21, 2002 | 02:45 AM
i stand corrected.
Minime515
Apr 24, 2018 09:52 PM
coreyhayman
11
Oct 4, 2006 04:51 AM
r6samson
Mar 31, 2005 02:37 AM
pip9
Jul 12, 2004 05:10 PM
JonGP4
29
Nov 21, 2003 10:35 PM
