Auto to manual swap problem
Hey guys, couple months ago i swaped with my friend my ek3's transmission from CVT to manual. Its a 1996 ek3 d15b 3stage vtec. The ecu is P2J-J62. After the swap the vtec wont engage. Why is this happening? I kept the automatic's ecu and harness. The car is working fine, we tried diffrent ecu's but it was reving up and down. Anyone could help me?
i'm not well versed in non-us sohc's, but honda from 96-00 commonly put a 3 wire idle air control valve on their automatic vtec engines, and a 2 wire on the manuals. my guess is the manual ecu you used was looking for a 2 wire iacv, and you have a 3. overwhelming odds on vtec not working would be the ecu looking for transmission solenoids that no longer exist, possibly putting you into limp mode. pics of the engine would be helpful here, given as there are tons of d15b variants.
edit: i just did literally two minutes of reading. you need to swap over to a 2 wire iacv and rewire, and the ecu you need should be the p2j-003
i'm not well versed in non-us sohc's, but honda from 96-00 commonly put a 3 wire idle air control valve on their automatic vtec engines, and a 2 wire on the manuals. my guess is the manual ecu you used was looking for a 2 wire iacv, and you have a 3. overwhelming odds on vtec not working would be the ecu looking for transmission solenoids that no longer exist, possibly putting you into limp mode. pics of the engine would be helpful here, given as there are htons of d15b variants.
tturbocivic0618
13
Apr 15, 2008 01:40 PM
deeweezy187
Aug 19, 2007 10:37 AM
