98 Civic window problem
Hey, so I've got a 98 Civic hatchback cx and my question is that my driver side window doesn't roll down or up properly. When I roll the window up it pop out of it's track close to the top and doesn't align right, I've try lubing the track and readjusting it as well but the problem still there. I was wonder if it's because my window regulator is bad? BTW my passenger side door works fine though.
I have had this problem in other cars from way back and it was the track it self was warn out. Only fix was to get a new/used track and I got one from the junkyard which fixed my issue. If the window has a plastic guide that holds it in the track that also may be damaged and an easy fix.
Alexpbnj
May 28, 2010 10:21 PM
vlc92189
11
Oct 9, 2007 01:16 PM
