Alternator replacement
lol why are you using a breaker bar ? all you need is a small ratchet and the bolt should easily break loose
it's only a 12mm head bolt and there are two bolts down there if i remember right, you might be on the wrong bolt
using your fingers, feel down there and make sure you are on the alternator bolt
and move that belt out of the way or you can just go under it if you don't want to move the belt, it's really tight right there
boomersz
Apr 29, 2007 06:57 PM
pryzmlyte
Jun 12, 2006 01:08 PM
