how to get teg to give codes
Old Nov 12, 2002 | 10:20 PM
Simple's Avatar
Default how to get teg to give codes
ok, in my friends 99 LS, the check engine light has been on for a long time, i know the thing went into safe mode, but all it does is stay on. im pretty sure its an o2 thing. but how cant i get the integra to throw a code so he can have it fixed?
Old Nov 12, 2002 | 10:27 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: how to get teg to give codes (Simple)
go under the passenger side, ont he right side under the glovebox. look for a bright green rubber connector cap, about the size of an integra clockface. pull it down, pull out the little connector, and insert a wire connecting the two holes.
now, turn on the car to ON (do not start it) and watch the indicator, long blinks indicates a tens digit (4 long blinks = 4_) and then the short blinks indicates the ones digit (5 short blinks = _5) so, putting 4 long and 5 short together, you get 45, which is too rich / too lean.
Old Nov 12, 2002 | 10:29 PM
phase12gsr's Avatar
damnit, just beat me to it.
it's right over the passenger's kick panel. look for this rubber green cap that has to connectors going into it. (they arent connect to anything) use the one that has two wires going into. just use some electrical wiring to stick into the holes and turn key to ACC. the car should start to give you some codes. HTH.
[Modified by phase12gsr, 11:29 PM 11/12/2002]
Old Nov 12, 2002 | 10:33 PM
phase12gsr's Avatar
oops, double posted. sorry
[Modified by phase12gsr, 11:33 PM 11/12/2002]
adambrasel
Oct 25, 2007 06:37 PM
Weapon_R
Feb 15, 2006 03:34 PM
showcarmike
Dec 25, 2002 09:51 PM
crxzc
Jun 16, 2002 10:53 AM
ITR-1303
Dec 29, 2001 05:22 PM
