automatic turbo on d16y7
Honest advice.... read and research on here and other places for about 6 months before buying a single part or touching your car. Then come back with your questions.
well the reason im asking now is because i want to do an automatic with turbo just wondering what id need so motor wont blow or tranny wont give. im just wanting 5-8 psi
The reason we suggest reading is because you will find this has been stated already hundreds of times. The first thing you will need to do is convert to manual. Anything else will be a waste of time and money.
Also, aren’t 96-00 auto transmissions notoriously “crap”? I seem to have read that quite a bit. If so, adding extra power would not be a good idea. And whoever told you a turbocharged automatic EJ is, well...
engine management on the obd-2 a/t is the hangup. obd-1 could be chipped, ecu will still work with the auto trans. obd-2 cannot, nor can you use a jumper harness to convert to obd-1, it will not run your transmisson.
robitjcivic
18
May 28, 2008 03:58 PM
