‘96 Spec DC2R B18C Issues
Old Jul 6, 2018 | 07:21 PM
PhantomDC2R's Avatar
Default ‘96 Spec DC2R B18C Issues
Hey everyone! Not new to the site but I just made an account because I finally need some serious help.
I was driving today, 2500 RPM or so in 5th, and then my car starts revving as though it’s fallen out of gear. I downshift to 4th and tap the gas, and it dry revs again, will not accelerate. By now there’s a strong smell of grinding metal and burning. I pull over and kill the car. The engine did have oil, however it was a little under the lower dot on the dipstick as of yesterday. Coolant was fine. NO fluid leaks on the road. I attempted to restart it and there was a nasty sound of metal on metal and it didn’t turn over. I added a quart of oil and tried again 30 minutes later, and it cranks but doesn’t catch. I pulled off the distributor cap and found the contact points scored and corroded.
This is where I’m at right now. No prior symptoms, 209,000KM on the engine and trans. If it means anything, it was very hot today, 32 degrees Celsius.
Thanks in advance everyone!
Old Jul 6, 2018 | 10:21 PM
Klasse's Avatar
Default Re: ‘96 Spec DC2R B18C Issues
Cambelt still in one piece? I'd take valve cover off to see how it looks and drain oil to check for bits of metal. Sounds a bit ugly...
Old Jul 6, 2018 | 10:24 PM
i will check the timing belt in the morning. I’ve seen that suggested a couple times now in my searches.
Old Jul 13, 2018 | 09:04 PM
Klasse's Avatar
Figure it out?
Old Jul 15, 2018 | 01:34 PM
Figure it out?
no. We’ve been playing with the distributor. We replaced the coil to no effect and purchased a new ignition module which didn’t fit. Finding correct parts for a JDM B18C isn’t easy in North America. A lot of parts don’t match up.
Old Jul 15, 2018 | 01:35 PM
Timing is fine. Cams move. Engine won’t turn over.
Old Jul 16, 2018 | 06:36 PM
K20.ek's Avatar
How long has it been since you replaced your clutch? Mayb having your transmission check would be good idea since it’s Reving up in gear
Old Jul 16, 2018 | 08:00 PM
dave7's Avatar
10 Year Member
^ Yea. Might it have something to do with the starter/flywheel/trans?
Old Jul 17, 2018 | 04:43 AM
** FINAL UPDATE **
We finally fixed it. After replacing the distributor cap and rotor, then the coil, it seems the issue was the ignition module all along, and after installing a new one the car runs. It seems blowing an ignition module is also a good way to cook the plates in the battery, so keep that in mind.
Also funny enough, the ignition module for a JDM Type R is the same as the one from a CRV which makes it a fairly cheap fix.
The car was driven through all 5 gears without issue. Thanks everyone for your help and concern. Have a great summer and hopefully I’m not back for a little while.
mato89
25
Oct 31, 2017 08:03 AM
guitarhero728
Oct 8, 2012 06:21 AM
lizathellama
14
Dec 16, 2011 06:35 AM
kyllcs
May 25, 2009 02:32 PM
kool168
Oct 21, 2003 10:51 PM
