Could A B18C5 @11:1 CR motor be turbocharged effectively?
Old Jul 6, 2018 | 04:07 AM
itr1244's Avatar
Default Could A B18C5 @11:1 CR motor be turbocharged effectively?
i been feeling the turbo itchy lately and was wondering if my engine could be boosted.??
b18c5
11:1 wiesco pistons 81.5mm bore
callilo pro a rods
stock b18c5 crank
m22xx cams
balanced & blueprinted
thanks guys
Old Jul 6, 2018 | 05:03 AM
2x0's Avatar
2x0
10 Year Member
Default re: Could A B18C5 @11:1 CR motor be turbocharged effectively?
b18c5
callilo pro a rods
stock b18c5 crank
m22xx cams
thanks guys
Everything would be good except for those cams.
Old Jul 6, 2018 | 08:06 AM
Chance EG's Avatar
Throw in some S2 tuner 1 cams and you're good to go. I'm assuming you're not going for some ultra high HP build.
Old Jul 6, 2018 | 09:49 AM
Balor_Gr's Avatar
Im around 240 hp on stock 11:1 B16 longblock a good 15.000 kms.
F20c can do 500whp easy on stock 11:1 pistons.
The bigger the overlap the better with high Cr, IF you plan on doing a very efficient manifold and big turbo setup. like top mount mani and at least 62mm turbine wheel. If on the other hand
planning on getting a small manifold and a small 300-400 hp turbo those cams will kill power.
EDIT you must be carefull on those rods. If they are not the SA id keep it like 350whp max and that not on a very torque heavy early spooling turbo.
Old Jul 6, 2018 | 12:37 PM
boosted94gsr's Avatar
Correct. The bigger camshafts with greater overlap reduce your dynamic compression ratio. All your parts need to be selected to work together like mentioned above.
Old Jul 6, 2018 | 02:09 PM
itr1244's Avatar
Default Re: could 11:1 CR motor be turbo'd ?
from their website
Pro-A Beam Rods: The A-beam rod is a light weight rod that is designed for high revving motors. It can hold moderate horsepower numbers and is the rod of choice for most street cars looking to push more power than the stock internals can handle, they are rated for up to 650whp
that's alot more than my power goal lol
and what's S2 tuner 1 cams
skunk 2 ??
Old Jul 6, 2018 | 07:46 PM
TheShodan's Avatar
Moderator
from their website
skunk 2 ??
Yes. Skunk2... Skunkworks
Old Jul 6, 2018 | 07:51 PM
Chance EG's Avatar
Default Re: Could A B18C5 @11:1 CR motor be turbocharged effectively?
Yes, Skunk2. The Tuner 1 cams are well suited for smaller turbo setups.
Old Jul 7, 2018 | 02:44 PM
itr1244's Avatar
thanks a lot guys
kielcivic
Apr 9, 2012 09:35 PM
norcalB18
Oct 11, 2010 11:57 PM
grundle
Apr 17, 2008 05:13 AM
Tonyl507
Jun 2, 2006 12:43 PM
ek9tl
May 27, 2006 06:42 PM
