92 prelude build
Old Jul 1, 2018 | 06:45 PM
Ty Smith's Avatar
Default 92 prelude build
Whats up guys I just got a 92 prelude 5sp, it doesn't have a motor, I have a m2s4 tranny. I'm new to the 4 bangerzs and I'm wondering what the best engine to get for it that has some power that i want have a problem dropping in and want burn a hole in my pocket?
Old Jul 1, 2018 | 11:42 PM
TimiK's Avatar
10 Year Member
Default Re: 92 prelude build
depends about your budget
Old Jul 2, 2018 | 09:28 AM
Ty Smith's Avatar
My budget is like 600$ but I want to get a engine with some power and I read a couple forums and I keep seeing the h22 and they say its pretty good but they say they are expensive.
Old Jul 2, 2018 | 08:45 PM
TimiK's Avatar
10 Year Member
you cannot get anything working with 600 - swap engine needs to be also rebuilded when you purchase it
Old Jul 3, 2018 | 02:27 PM
SubwayH23's Avatar
Why would you buy a car with no motor and then only have $600 to play with to get an engine?
Should’ve looked up how much an engine was before you bought it
Old Jul 5, 2018 | 09:37 AM
Prudz_lude's Avatar
It's possible but you will need to find someone giving away a long block, possibly in need of a little refresh. The most important part you'll need to the tools and knowledge to do it all on a budget of $600, which is no easy task. You'll also need a junkyard close by with a prelude that can be used as a donor car. Again, possible but a lot of things need to line up just right and you need to know what you are doing and what you are looking for.
Old Jul 5, 2018 | 11:49 AM
Accordian47's Avatar
10 Year Member
So with a 92 Prelude and a $600 budget, your going to want to stay OBDI I am thinking since you have an OBDI car. Your going to be looking at either a H or F series engine produced from years 1992 through 1995.
Here are your options in rough order of cost and power:
  1. H22A (Japanese Market)-Either 187hp/152tq or 197hp/161tq
  2. H22A1 (US, Canadian and Australian Markets)-187hp/153tq
  3. H22A2 (European Market)-182hp
  4. H23 (Japanese Market)-160hp/156tq
  5. H23A1 (US, Canadian and Australian Markets)-160hp/156tq
  6. H23A2 (European Market)-160hp/154tq
  7. H23A3 (European Market)-160hp/154tq
  8. F22B1 (US and Japanese Market)-145hp/147tq
  9. F22B2 (US and Other Markets)-130hp/139tq
F22B1 is a SOHC, VTEC, 2.2L Motor that makes145hp/147tq. They came in the 94-97 Accords and the Accord and Prelude share a very similar engine bay so if your really tight on cash it's a good compromise to say an H22 or H23. I have seen F22B2s and F22B1s go used for $300-500.
Budget permitting, you could always turbo the lesser powerful F series and make more power than any H or F series makes stock but I'm not sure if you want to go that route.
Check out ebay, and various online sites that offer used engines, some are JDM only (Japanese market) but finding any of these motors shouldn't be too hard. Google it.
Old Jul 6, 2018 | 10:02 PM
KookiDowg's Avatar
5 Year Member
Vague thread is vague. I don't own a fourth generation Prelude as of yet but definitely something to ask yourself is what's your end goal? Do you plan on boosting or sticking with the bare NA? From what I can recall after lurking and researching on this car for quite sometime, the H22s is the best route if you plan to stay NA and H23 for a boosted path. Feel free to correct me if I'm wrong anybody.
Old Jul 7, 2018 | 02:28 PM
10 Year Member
Id go with a F series man, any H series is gonna cost you too much, I mean, by all means, throw an H series in there is you can find one cheap enough.
F22B1:
Found in: 1994-1997 Accord EX and in 1993 JDM Accord models 2.2VTE, VTL & VTS as well as the 1997 Acura CL.
  • VTEC
  • 2.2L (Same displacement as the H series, more than the 2.0L 4cyl engines found in older Preludes)
  • OBDI (In '93,'94 and '95 Models: Important due to the fact that you have an OBDI car)
  • 145hp
  • 147tq (More than alot of the other 4cyl Honda motors)
  • 8.5:1 Compression (Great for boost yet still high enough for good throttle response and power)
  • Cast Iron Cylinder Liners (Strong and again, great for aftermarket pistons or boost)
  • Fairly Cheap (They go on eBay from anywhere between $350-$600)
  • They are strong and durable motors that can go for nearly 300k miles
  • They make great power with a simple turbo kit and hold up well
Ty Smith
Jul 1, 2018 06:38 PM
Denis92lude
Jul 24, 2013 09:59 PM
oneprelude
May 18, 2007 09:04 PM
SiR Inspired ED7
Jun 23, 2004 09:29 AM
arjunsan
Jun 21, 2004 05:55 PM
