03 EP3 ECU Tuning?
So, I've been doing all kinds of research to see how I can build my K20A3. My other question regarding this is, how do I tune my ECU to be able to run all the mods after installation? Even just tuning in General? Lol.
Kpro. Get a new one or send yours off. Otherwise, standalone ECU management.
If you're not messing with the cams, injectors, or boost, you really *don't* need a kpro, but it always helps
Last edited by toyomatt84; Jun 30, 2018 at 06:56 PM. Reason: Fixed spelling of "Kpro".
I put a KPro on my A3 in advance of my upcoming K20R swap. Makes a *huge* difference, the car is actually pretty fun this way. I'm enjoying it, b/c since I don't care about the A3 I increased the redline to ~8200....
Seems like just buying a swap would be a more direct route to automotive joy than polishing the turd of an A3.If I was building a motor it would be the K24 block/k20A head frankenstein not the A3.
Last edited by feralcomp; Jul 2, 2018 at 08:10 AM. Reason: put a2 meant a3; fixed.
Not everyone has the f[inancial ability to pay $800+ for that setup. kpro is a good investment in that the engines can be swapped without messing with the ecu other than new tuning. I'd get kpro, save for a swap, then get it when I blow the A3
OP: " I was planning on changing out my rods, heads, and cams. "
That's $800 and then some.
OP: Buy a different motor (and build that if you want); don't build the A3.
ETA: I mis-typed A2 above when I meant A3, made my initial post really confusing. Fixed it.
Well what I'm saying is you'll need kpro to put in another motor, certainly anything modified like a frank. So get the ECU first, that way when you score the engine it's good to run asap
Or just flash it while you have the A3. Hondata will then give you a credit on the whole Kpro package. Better to do it in increments, unless you're fully agreed to doing the swap 100% down the road.
Well I was thinking about a Z3 swap. For the cams and other things I found a setup for forged pistols and Rods with the cams under 1k. The only reason that I'm finding it hard to swap is my other financial obligations and I live in Hawaii where everything is f'n expensive. I mean it's 8 bucks for a gallon of milk. And there isn't that much people locally willing to sell a motor for less then 1k.
