Hi I'm need of some help, three wires came out of their connecters. And I think because of this my 2000 honda civic will not start. I was wondering on how you put the wires back into the connector so it can start again? The wires are black/yellow,white/black, and yellow.
Re: Wires came out of connector the car wont start
Not a problem. In order to get to the wire harness, remove the steering column cover (3 Philips screws) and you will see the ignition switch on the left side of the column. Remove the 2 screws and cut the zip ties along the way. Follow the wire harness and you will see the existing brown connectors.
