Transmission & Drivetrain Gearboxes, Differentials, Clutches
I need synchro order
Old Jun 27, 2018 | 05:15 AM
AllDay-DB8's Avatar
Default I need synchro order
Hey guy like the tittle say I am replacing the syncrhos in my transmission. I have the syncrotech 1-5 gear syncrhos but I don’t know where each one go they all look really similar I don’t know if I am explaining my self right.Thank you guy
Old Jun 28, 2018 | 01:56 AM
holmesnmanny's Avatar
Default Re: I need synchro order
call synchrotech
Old Jun 28, 2018 | 04:04 AM
AllDay-DB8's Avatar
Thanks I would do that is the only option I have I didn’t find nothing online
Old Jul 3, 2018 | 02:20 PM
94EG8's Avatar
Seagull Management
They will only go where they're supposed to go. Depending on just which transmission they're for 1st and 2nd will be the same and 3rd and 4th will be the same. In some cases 1st and 2nd will be different where 2nd will have a dual cone synchro.
Old Jul 11, 2018 | 03:57 PM
AllDay-DB8's Avatar
Thank you I have all the synchronizer in but I think my shifter holder assambly is bad the 3 nibbles I have to line up with the 3 gear selesdor I can’t line it up the shaft inside I don’t if is suppose to move up and down but mines don’t move and when I try to shifter it won’t let shift
Old Jul 14, 2018 | 07:55 AM
94EG8's Avatar
Seagull Management
Post some pics.
I'm just guessing by your description of the problem and your username that you have a B-series transmission. You will not really be able to shift through the gears with the top half of the case off. The top half of the case supports the shaft that the shift change mechanism pivots on and it won't stay in the correct spot. Try assembling the transmission with no liquid gasket to check the shifting operation on the bench, if it seems to shift ok pull the top half of the case, seal it and reinstall.
Old Jul 14, 2018 | 08:42 AM
AllDay-DB8's Avatar
Originally Posted by 94EG8
Post some pics.
thank ou yes that was my problem I was disappointed alredy thinking I did something wrong thank you
95islegreensol
14
Feb 3, 2018 01:41 PM
Mr_Si-R
Honda Civic (2006 - 2015)
11
Apr 6, 2010 09:22 PM
J4k3
Feb 25, 2006 02:31 PM
Syruz
Mar 31, 2002 11:29 AM
